im getting 2 12" Infinity Kappa Perfect 12.1, and i have a Power Acoustik A2400db amplifier.. is that too much power going to the sub? will they blow out?
do you already have this amp or going to get it. I found it much cheaper in a few other sites. I was looking at it and pictures from each angle and it doesnt have any fuses on it.. kinda odd. Since its not CEA compliant it prolly won't actually put out that much wattage. Just use a meter and turn the gain up to match the rms you want no biggie. I am running 500 rms on a 12.1 and it has lasted years.
1. I don't know what kind of METER your talking about, or maybe i would have an answer.
2. It doesn't matter how much power is actually available to the amplifier. What matters is making sure your gains are set correctly, to ensure that you won't blwo your sub(s).
I had a 15" kicker CVR dvc 4ohm that is 500 rms 1000 max and i had 1100watts going to it with a Hifonics bxi 1606d at 2 ohms. Don't worry about overpowering it just keep your gains low and you should be fine.
