keep blowing fuses?
it could be becuse u dont have a lighting cap if u dont or u dont have enough power supply maby
What the hell are you talking about? Capacitors have nothing to do with his fuse blowing, but not getting enough juice from the 'battery' aka power supply:laugh: could cause his fuse to blow.
get a bigger battery with more amps and also cold cranking amps, if u run two batts, the one under the hood should have a bigger amps # dont worry about cold cranking amps then.
Mike
http://www.bcae1.com/fuses.htm
If you have a piece of equipment (especially an amplifier) that has played fine for a while with a given size fuse and the fuse blows, do not replace it with a larger fuse. I'd actually suggest temporarily replacing it with a fuse ~1/2 the rating of the one that blew. If you have a 200 watt amplifier that's been running fine with a 30 amp fuse and the fuse suddenly blows, replacing it with another 30 amp fuse is fine but I'd suggest trying a 15 amp fuse first. With the volume set to its minimum position, the amp should power up and idle with the smaller (lower rated) fuse. It should also play cleanly at a low to moderate volume. If the fuse blows with no volume, there is very likely a problem with the amplifier. If it does not play cleanly, there may be a problem with the speaker(s) or wiring. If it blows the fuse at very low volume, there is most likely a shorted speaker or a short in the wiring.
w1dude
w1dude
Louisville, KY
dleccord
michigan born
    May 14, 2026
michigan born
    May 14, 2026
