TL design needs review
MX SERIES
Product Dimension12”
Mounting Depth - 10.25”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 8.5”
Motor Depth - 2.5”
Basket Depth - 7.75”
Displacement - 0.19 cu. ft.
Weight - 33 lbs
MX SERIESProduct Dimension12”
Motor Width - 8.5”
Motor Depth - 2.5”
Weight - 33 lbs
yah. what do you think it would sound like with the sub inverted? do you think this box is designed good?
inverted wont make a difference w the sound, and this one doesnt have a pole vent so u can mount it as close to the wood as possible.
but
you need 10 + inches of depth....You dont have it there.
you have to invert it.
Will the line incorporate any type of stuffing? You need to add some stuffing and lowpass it at 50hz with a steep slope. Straight lines like that have a nasty peak round 70-80 hz...the stuffing and steep slope well help...
I have never actually tried mounting it inverted before, if you do, maybe try switching the phase....
To figure out the needed information for a transmission line:
1: The subwoofer needs to have a Qts of .40 or lower
2: Get the subwoofer’s Fs
3: (1130/Fs)/4 will give you the length of the 1/4 wave length needed in feet. This needs to be the length of the port. Don’t worry, it will be long.
4: Next you need to figure out the port area needed, which should be the same as the subwoofer’s Sd. If you don’t have the Sd, here’s how to figure it out: Measure the subwoofer from center of surround to center of surround and divide that by 2. Then take that measurement and apply it like this: (measurement/2) x (measurement/2) x 3.14, that will give you the Sd. This is also your port area. If you are using multiple woofers, just multiply that by the number of woofers you have.
Confused yet?
5: Now you know how much port area and port length you need, and there is no chamber, it’s all one port, so now all you have to do is figure out how to get that length in the area that you have to work with.
You can thank stratusrt01 on the realm fourms, that's who I got this info from, I have not tried it yet.
thats the same formual i used. think im going to try out my design but with the mx inverted.
Confused yet?
sinosic
Idyllic Enclosures
sinosic
roseville,ca
Fast1one
