tired of blowing subs
Agree.
Are you going to blame Fi when you blow the new one?
I remember seeing a BTL take 10kW several years ago, and still have a pristine coil. The fact that people blow them up is a testament to...something, I guess //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The orion hcca subs are crap. If someone is trying to talk you into a jugg then at least he picked a pretty tough sub to sell ya.
As far as "hits real hard" that's all in perception and how much you want to spend. Quite frankly that JL 1000 is pretty small but would probably get ya through until you got something with more horsepower.
Some brands you should look at are
FI Car Audio - http://www.ficaraudio.com
Mach 5 Audio - http://www.mach5audio.com
Audioque
Resonant Engineering
Diamond Audio D6
Alpine Type R
good luck
I don't know if I would trust this guy. He lives in Greenland //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
338
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
steelewise
steelewise
SoCal
snoopdan
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
