pwnt by pat 10+ year member
Pat for Prez 2024 - vote!
Well, I've found a set of used horns and x-overs for the horns that I'm going to grab. Now I need to start thinking of some midbass/range. Origionally, I thought that I would just get something to replace the stock 5 1/4 speakers in my doors. I could cut the holes bigger but I want to keep all the stock equipment so if I decide to sell the car, I can keep my precious audio equipment.
Then I got to thinking, 'It'd be cool to make kicks. I could do some koda 6's or xxx midbass there.' Now I'm thinking, 'midbass, check, high/mid, check - midrange?' I'm not sure if I should get some midrange to complete the whole thing.
I have a four channel amp and I'd only be using two channels. I can wire it up so the amps's rca-out feed the other two channels rca in's. That's no problem.
I was thinking maybe Adire's AV5. There aren't a lot of quality 5 1/4's that I've seen that are any good. Also, the AV5's are cheap. I'm not sure if it can run IB though. If I got a midrange, too, it'd have to take 100rms. Anything less wouldn't be able to keep up with the horns.
Also, I'll have no tweets in the stock location. Maybe I should look at some comp sets for the tweet? I thought that I'd just ignore it and let the horn's do their job! Coax I guess I could use, I'd just remove the tweet. Maybe Kicker R5c's?
I don't know. Price? 125'ish max for the pair. Other req's: 5.25", 100rms, wireable to 2ohm or custom ordered wired for 2. Grill? If it comes with one, that's cool. If not, oh well. I don't need a grill.
thoughts?
Thanks
thoughts?
Thanks
