Three MTX 10"s ... What amp?
  • 4
TBIRD 38 LX
I have the three MTX 10" 6000 subs in a sealed box kit from Crutchfield. 12 ohm subs wired in parallel for total 4 ohm impedance/ 46-150 hz freq response. 150-750 watts RMS. 1500 watts peak.
Now ... for the good stuff...
You think the Lanzar Vibrant 238 would be a good amp? Its 2 channel 800 watt amp.
The amp is like 110 bucks on ebay with shipping ... I think its good bang for the buck, better than that "Pyramid" garbage.
If not, what amp would bump 'em, under 2 bills?
Or should I sell the subs, get two Kicker Comp VR 12"s and a similar amp?
Any other ideas/suggestions?
thanks
Andrew
Originally posted by TBIRD 38 LX I have the three MTX 10" 6000 subs in a sealed box kit from Crutchfield. 12 ohm subs wired in parallel for total 4 ohm impedance/ 46-150 hz freq response. 150-750 watts RMS. 1500 watts peak.
thanks
Andrew
first off watch yourself on ebay //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif make sure they are legit (bad past experiences) Lanzar would be a good amp...
may i suggest to you something eles
4 x 125 Watts RMS at 4 Ohms
·4 x 250 Watts Max at 4 Ohms
·2 x 500 Watts Max at 4 Ohms Bridged
·4 x 200 Watts at 2 Ohms
·Electronic Crossover Network
·Bass Boost Circuit
·Bridgeable at 4 Ohms
·2 Ohms Stereo Stable
·Tri-Mode Capable
·Gold RCA Inputs
·Line Outs For CH1/CH2/CH3/CH4 channels.
·Power & Protection LED Indicators
·Advanced Protection Circuitry
·Soft Turn On/Off
·Remote Control Bass Booster
·Frequency Response: 15 Hz - 35 kHz
·S/N ratio: 90dB
·Dimensions: 11.5"W x 2.3"H x 14"L
and were you can get it is in your message or pm or whatever you wanna call it
ty-
I have the same setup as you do, except my 10's are DVC 4 ohm subs, wired to 2.66 ohms, i have the MTX 6500D w/ EBC control that i picked up for 250, without the EBC you can get it for around 215$, anyway, even wired at 2.66 this is a great combo, it hits super hard, 775 watts. And with your subs being wired to 4 ohms, it would be an even better combonation. P.S. this is the second biggest amp MTX produces, the 8100D costs around 325, but puts out 1500 watts peak.
Originally posted by tglisson first off watch yourself on ebay //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif make sure they are legit (bad past experiences) Lanzar would be a good amp...
·Bass Boost Circuit
·Tri-Mode Capable
·Gold RCA Inputs
·Soft Turn On/Off
·S/N ratio: 90dB
ty-
what are all the stats for?? and please stop posting them, they aren't all that important.
and, for the MTX subs, go to http://www.ikesound.com, and look around, http://www.thezeb.com , there are a couple of others.
Or, you could buy my PPI amp, 500w RMS @ 4 ohms.. just thought i'd add that in there //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Originally posted by gellis4 what are all the stats for?? and please stop posting them, they aren't all that important.
Dude I just figured that, if he could see the specs, then he would be more interested in the amp, but if you think its a hassle then I wont...
ty-
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Originally posted by tglisson Dude I just figured that, if he could see the specs, then he would be more interested in the amp, but if you think its a hassle then I wont...
ty-
some of the things are helpful, but if someone was really interested in buying something, they would find it out themselves. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
5
Don't do it, you're only looking for issues. You only want subs that are the same. Subs with different specs will cause sound quality issues
746
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
865
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
TBIRD 38 LX
TBIRD 38 LX
Jacksonville, FL
gellis4
Decebal
    Jun 10, 2024
