I run over 2k on s stock 150 but I'm tuned for SQ not loud as ****. Stays in the 14s at idle.The OEM alt is 80 at idle and 150 at 2200 rpm. It's high for factory because of the EPAS I'm told. What's gonna happen if I use the OEM?
How much space is available in the engine compartment?The OEM alt is 80 at idle and 150 at 2200 rpm. It's high for factory because of the EPAS I'm told. What's gonna happen if I use the OEM?
If possible you can always have a fabricator create a bracket and just Mount an extra pulley between the two alts to relieve stress on the alternators.
Sent from my draconis using Tapatalk
If you plan to keep the vehicle and plan to continue upgrading even for daily usage its best to have the room or else you will be forced to keep a good amount of batteries for when you get in the bass mood.Hmmm... I'd have to look again. The stock alt is buried at the bottom of the motor and fabricating brackets for dual alts is really more involved than I wanted to get. If this were a walled off setup solely for competition then I'd be all for it.
Probably not any room though. Stock is on front left bottom of motor.
Yea I'll have 1 aux battery and it's not gonna run full tilt all the time. Moderate volume on drives to and from work. Full tilt for showing off.If you plan to keep the vehicle and plan to continue upgrading even for daily usage its best to have the room or else you will be forced to keep a good amount of batteries for when you get in the bass mood.
You wont kill the alternator if you don't ride full tilt all day. Give time for the batteries to charge with less of a load going.
Yeah, it should be good. I'd go with that over your other selections.Yea I'll have 1 aux battery and it's not gonna run full tilt all the time. Moderate volume on drives to and from work. Full tilt for showing off.
I was recalling some old brands I used to know and remembered AA. They don't make the Avalanche anymore I guess but this seems legit. What do y'all think?
Mayhem 15" Ascendant Audio 15" 2500W Mayhem Series Subwoofer - 1800woofers.com
Looking like a change of plans. If I use all 40" width of my cargo area I'll leave no room to fit a battery. So I can drop to 30 or 32 inches and drop to about 3 or 3.2 cubes. So the question is, should I go with a lower power 15 and go without the battery? Or go with a high powered 12 and get the battery? Or will I be okay with 3 cubes on an AA Mayem 15?
This looks pretty serious.
I wish. I'm limited on space if I am gonna fit a battery back there. I want a 15 but at just over 3 cubes net I'm gonna be stuck with a 12.Can you fit a box this big back there? A well thought out 15" Mayhem build... - Page 3 - SPL & SQ / Fabrication - SSA Car Audio Forum
