Those of You Using Components in Q-Logic Kickpanels
  • 3
james33440
FL
I was wondering if anyone has experienced any problems using components in Q-Logic kickpanels? I was thinking of adding either another set of Kicker Resolution RS6c components into my kickpanels or swapping the RS6c components that I have in my doors to my kickpanels and putting in some Kicker Resolution midbass speakers in the doors. Regardless, I will be putting in some components in my kickpanels. Now, should I spend the money on the Q-logic kickpanels or get some custom made fiberglass pods done?
i beg to differ, q forms from a few years ago weren't made that great, i've seen a few and wasn't impressed, but the newer ones are made quite nicely. i got a set for my 02 civic, and i was impressed at how thick the plastic was, not to mention how well they fit. if you have a newer car, i would try out the q forms, $150 isn't much to get improved imaging. going from the speakers in the doors to q forms is very dramatic, however, i will agree with Gauntlet, if you have them custom made, they will be imaged how you like it, and will sound better, but they will definately cost more.
Originally posted by slick316 i beg to differ, q forms from a few years ago weren't made that great, i've seen a few and wasn't impressed, but the newer ones are made quite nicely. i got a set for my 02 civic, and i was impressed at how thick the plastic was, not to mention how well they fit. if you have a newer car, i would try out the q forms, $150 isn't much to get improved imaging. going from the speakers in the doors to q forms is very dramatic, however, i will agree with Gauntlet, if you have them custom made, they will be imaged how you like it, and will sound better, but they will definately cost more.
But they're still plastic, which is much more conducive to breaking and cracking than fiberglass is. I weigh 205, and I've been able to stand on properly-made fiberglass kick panels without any form of flexing at all; I can't say the same for Q-Logic. Granted, that kind of pressure is never going to be applied to them in a realistic application, but it shows the huge stability differences between plastic and fiberglass.
And custom-made fiberglass kick panels should only run you around 200 or so; the extra 50 is well worth it in my opinion. Or you can just do it yourself, which would run maybe 100 bucks or so (depending on the quantity) plus labor. Fiberglassing really isn't as hard as a lot of people make it out to be, it's just a tedious (and messy) process.
yea, you're right, they are still just plastic, but for me, it was the best choice. i couldnt find a place locally that can build me fiberglass kicks for anyless than $300, and i didn't have the time nor effort to make my own. you can always line the inside of the q forms with dampening material, or seal them off with fiberglass, but for me, a little dynamat did wonders and they sound great with my HEX's.
for $200, i would definately get custom made kicks, but that wasn't an option for me.
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
609c is very good for their price. I haven't used the Pioneer but I'd figure if they're comparable price they should perform similar.
actually have 4 coaxial in the doors. so better for me to procure 2 comp and put in the front door and send the 2 front coaxial behind the back seat.
11
763
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
620
james33440
james33440
FL
slick316
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
