skadude016
ok good i was like wtf?sarcasm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How, exactly?Plenty of big amps can be cooked seeing to little voltage //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
No, you can't, but that doesn't mean you'll "fry" your amp. Stop being dense.So I can run a 5000 watt amp on a stock elctrical system and have no problems, glad I learned something.
Anyone reading this thread who knows anything about a car's charging system knows you are making a fool of yourself, case in point. The guy runs his amps at too low of an impedance, and your conclusion is the amplifiers blew because of too little system voltage. Uhm... lol? //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gifThats true, he also doesn't have enough voltage to keep his amps out of protect and from dieing. You can't run an orion 2500d with one battery, you can but it wont last long, case in point.
Beemer740 how many subs are you running one or two? and how do you have them wired up?
I agree, an arguement is not needed. I just want to make sure the guy gets the right help, whether it ruffles a few feathers or not.I'm honestly not gonna sit here and argue, I'm just trying to help the guy out, if you want me to explain it to you then pm me.
thank god... I was losing faith...I would LOVE to see you try and explain that position. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Sounds to me like the most likely problem is the amps are being played at too low of an impedance.
whoa whoa whoa... ok ... + and - wire from each terminal on the sub... now are all of those amps mono single channel amps?i have a single 12w7 i honestly dont know if its single or dual vc because i bought it off a guy a while ago...theres a positive and negative wire one in each terminal in the sub then i bridged the amplifier....all my amps powered up none were in protect but all dont put out any output...thats why im thinking i keep blowing the output fets...the gains were not set more than 1/4
