This just in...my car is SH!T....
personally from what u have done and havent seen any improvement and instead of wasteing money on trying to fix it and that fix not being right, i would take it in to the shop and have them look at it, or go to a camaro forum and ask would be a better idea, just to save time and money
just dropped it off...the guy is gonna look at it tomorrow
The other day my car started hesitating as i was accelerating through the gears...no specific RPM range, and it happens in every gear...
The SES light is on, so we had it scanned...and it threw a 102(MAF or VAF low circuit input)....
Then we realized that no exhaust was coming out of my pipes....so we have new cats put on my car, and that problem is fixed....So i get in to go home, and the SES light comes back on and it does the hesitation again before i get out of the parking lot....
We have replaced my PCV valve, we changed the EGR vavlve, and now the catalytic converter...and it has new plugs and wires....
Any ideas on what the problem could be and how to fix it?
Thanks...
it could be a bad coil, could also be a bad ground somewhere that is partially shorting the computer, i had the same problem...
i am a smog tech and if u came into our shop with that problem this is what we'd tell you: "get it diagnosed and repaired. thats it." or u can trial and error yourself and have a very good chance of wasting money (which i think youve already done since you said your replaced the EGR, cat, and PCV valve). i have no idea why you chose to replace the PCV valve, though,all that does is **** the blow-by flammable vapor into the intake to make sure you burn every last bit of fuel and vaporized fuel.. it's an emissions component it doesnt have anything to do with performance.. and you said your cat was clogged to the point where exhaust couldnt leave through it? so the rhodium and all the other elements in your cat broke and clogged up your exhaust? did u overheat in the past or something? u replace with a factory cat? just to let you know, factory OEM catalytic converters perform significantly better than aftermarket cats. you probably wont care though, if you dont have a smog program in your state. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you dont get this problem fixed tomorrow let me know.. my dad has had 30+ years with all kinds of cars in the REPAIR field.. he knows all the common problems that cars have and ill ask him tomorrow at work what he thinks it m ight be.. i bet you hell have a good idea.
Thanks...
my suggestion would be the Oxygen sensor when they act up that seems to be the symptoms
chris96camaro
Foreign and Domestic
chris96camaro
Charlotte, NC
937DYTBOI
