think a 15" Type R can handle 1100wrms?
what size sealed?
the box isn't built yet but it could be from 2.25 to 2.7 cu ft sealed. I can go bigger or even a bit smaller but I was building a 2.25 cu. ft enclosure this weekend and was going to throw some poly fill in (2 lbs) I can change the size of the enclosure though
Are you saying that Directed amps dont put out rated power:eyebrow: .
He is probly stating that with impedance rise you wont see that much power or resistance. 1ohm could very well turn out to actually be 3ohms or higher depending on the box.
But...then again as the note changes so does the resistance. So chances are that it WILL a some point see the full wattage, but for a short period of time.
lubetek
lubetek
Riverside, California
nissanrider06
