the12voltsux Build LOG HHR 3 RE SE's 12"
You Likey?
  • Total voters
    70
chunky cumz
past due splooge
3,522
in ya mouf
Here is the build:
Car:
2006 HHR Black 2LT 2.4L
Already Installed
Head Unit: Panasonic
Volt Meter: Stinger Digital Red Volt Meter
Front Setup: Pionneer Premier Comps
Rear Setup: Pionneer 2or3 ways(cant remember Model)
TO BE INSTALLED:
Subwoofers: 3 RE SE 12" Subs @ 4 Ohms
Sub Amp: Power Acoustik 5500D Gothic Series Mono Amplifier
Speaker Amp: Power Acoustik OV4-840 Gothic Series 4 Channel
Equalizer: Pioneer DEQ-7600 Digital Signal Processor (Full Din)
Wiring+: 1/0 Guage to be wired through out car - 2 13-14' strands (bought from Bones22)
EFX PDMWF4D 4 Posistion Mini ANL Didgital Distribution Block
6 Channel RCA Cables 17' (from Equalizer to Amps) (bought from ls2poweredgoat)
4 Channel RCA Cables 17'
150 amp mini anl fuse
40 amp mini anl fuse
HHR Double Din Dash Kit
25' 10 gauge speaker wire
Sub Box: 7 cubic feet before displacement ported (see photos
Battery: Kinetik 2400HC(bought from 18inchjeepin)
Still need to pay for:
Sub Amp: Power Acoustik 5500D Gothic Series Mono Amplifier(will pay for on Sunday)
200 amp Fuse Holder, go from battery to disto block(will pay for tonight)
A few 1/0 Gauge Terminals(will wait for install to see how many i need)
This should be done in the next 2 weeks.
Hmmm.. Am i forgetting anything?
Ls2poweredgoat is building the box
Pics:
6 channel as well as 4 channel rcas?
6 channel to go out to the amps
I am not sure how the h/u and the equalizer hook up... But i guess they dont hook up via RCa cables so scartch the 4 channel set. I only paid like 5 bux for em anyways.
I didnt initially have plans on buyng the equalizer, thats why i bought the 4 channel ones
sounds pretty decent...we all should chip in a buck or two so that ls2 can pick up a god **** router //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so you have 2 runs of 1/0 wire. one 150amp fuse and one 200amp fuse? why not get two 200amps or even two 250amps?
with 3 subs in the top your going to want to double up the wood. just make 2 layers on the top so it doesnt flex so much. glue and screw them together.
+200 amp fuse + Distroblock 40amp fuse to 4chn amp, 150 amp fuse to sub amp + amp - ground
its looks **** good tho!
yes..his jigsaw skills are getting better and better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 on the fuses...
and kinda x2 on the double-baffle...but I believe bracing would be more effective..
And it looks like this should be good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
16
761
919
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
805
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
870
chunky cumz
past due splooge
chunky cumz
in ya mouf
bigbangtheory
DEW123
    May 7, 2024
DEW123
    May 7, 2024
