The Official Type R Thread
read through the thread, if you know what you are doing its a piece 0 cake.
I would love to, but it would probably take me 5 hours to go through all 150 pages.
Also, I am looking for the T/S parameters for the Type R DVC 4 OHM. I ran a search on this thread for "t/s" but nothing came up.
i really cant stand RE, infact, dave mocked me 2 years ago, and told me MT's cannot be used daily. douchebag.
BUT ANYWAYS.
i suppose the SE would prolly take the SQ trophy, entirely install dependant though.
You are right, or you could get an amp that would do 500rms at 4 ohms.
thanks alot for the response. this is my current mono amps specs:
Description
The KAC-8151D mono subwoofer amplifier uses its highly-efficient Class-D design to pump out big power from a small package up to 500 watts RMS (at 1 ohm)! Kenwood builds in a variable low-pass crossover, adjustable subsonic filter, and selectable bass boost so this amp can adapt to any bass gig. The KAC-8151D also includes a remote bass boost control, so you can adjust the bump right from the driver's seat.
200 watts x 1 at 4 ohms
400 watts x 1 at 2 ohms
500 watts x 1 at 1 ohm
1-ohm load capability
requires 8-gauge power and ground leads wiring and hardware not included with amplifier
50-200 Hz low-pass crossover, 18 dB/octave
subsonic filter (off/15/ 25 Hz), 18 dB/octave
bass boost (off/6/9/12 dB at 90 Hz) with wired remote
speaker- and preamp-level inputs
preamp outputs
dimensions: 11-7/16"W x 2-5/16"H x 11-1/4"D
Is that perfect if i get only one type-r in a ported enclosure?
aight guys...new topic, im gettin a single 12" type r...and its bein powered by a kenwood 500/1...im lookin for SQ...so i need ALOT of range in my bass...im already thinkin fiberglass sealed box...and other suggestions besides that...btw i have type r components in the cabin which are screamin fo ra sub so not only does it have 2 b accurate but also LOUD...
justchillin
justchillin
DC Metro
liquidswords
Mike Mccabe
