THE OFFICAL 911 was a inside job thread
Was 911 an inside job?
  • Yes.
    Votes: 94 47.7%
  • No.
    Votes: 86 43.7%
  • Not sure yet but I will visit <a href="http://www.UniversalSeed.org" rel="external nofollow">http://
    Votes: 17 8.6%
  • Total voters
    197
Are you a scientist? no, the heatsink theory is a theory... "much worse"? NOBODY took heat measurments! There is no way to know how bad the fire was...
well it certainly wasnt as bad as the madrid fire. And that building did not collapse. Not to mention as someone already did, there were people in the holes of the WTC where the plane hit and firefighters saying they could put hte fire out. Not too hot it seems.
Face it, there was much more to Sept 11 than you are led to believe.
J
Yeah, steel does have to hit its melting point to melt...why the hell would you claim otherwise?
"Well, the melting point of steel isnt actually the physical melting point, its about 1000degrees less than the real melting point..at least for the WTC's"
This is why I'm going to leave this thread, you guys continue to flaunt ignorance up and down and I;m not going to keep playing physics teacher with you anymore...
One last lesson,
no, steal does not have to hit its melting point for its strength to be compromised... ANY heat will make it lose strength, all melting point is, is the temp as which it will liquify.. you apparantly think steal has to liquify to lose any strength... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
This is why I'm going to leave this thread, you guys continue to flaunt ignorance up and down and I;m not going to keep playing physics teacher with you anymore...One last lesson,
Look at the Madrid fire which burned hotter, more intense, and LONGER than the WTC. It did not collapse. The steel structure did NOT collapse.
There is ZERO definitive evidence to back that up. Nobody knows for sure how hot the WTC fires were. I'm not saying "they collapsed from fire", I'm saying its a POSSIBILIY, even though a slight one.
First of all, QUIT IT WITH THE FUCKING JET FUEL! There was a fire! The fire was burning more than jet fuel....ALSO! The steal did not have to hit its melting point to fail...
What else was the fire burning besides desks, chairs and papers?
You're right, steel does not have to hit its melting point to fail. There are facts that show the variations between the temperatures that jet fuel burns at, and the temperature that different alloys of steel starts to fail at. Do your own research and come to your own conclusions.
No, I agree it lost some structural integrity, but not enough as that compared to other buildings. You completely negate the fact that the WTCs were the only buildings in ALL OF ****ING HISTORY OF THE GOD **** EARTH that have ever fallen because of a fire.
The heatsink is as valid as a heatsink on an amp. Metal spreads out its heat, exact same principle as in the amps you use in your car. Except the WTC was on a much larger scale, so more heat was dispersed over a given area. If you belive the heatsink theory is a theory, then tell that to amp makers all over the world. Maybe you can convince them that heat/aluminum do not spread their heat.
There is a way to know how hot it was... Do you think the WTC's were hotter than the Madrid fire? Do you? Answer that.
Now you're just being a jackass. //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
I'm leaving too. This thread sucks.
That works for mild grade steel, but the steel in the WTC was high-grade, and certified to burn at over 2000degrees. The very same people who built the building, and certified the steel came out and said it was impossible for the steel to melt. Regardless of what anyone else says, the very people who built the building said it was impossible for the steel to melt, let alone get that hot from jet fuel.
That article is worthless.
I did not read what everyone else wrote, but if you get into some forces then you realize that when the heated steel, regardless of grade, is under compression and tension, you do not have to reach melting point to see failure. This is the exact reason i did not link the rest of the article.
A very highly unlikely possibility. If firefighters could get up that high then the fire was not as intense as it would have NEEDED to be to even SLIGHTLY compromise the building.
J
nothing really, my point is that these guys are too caught up on the burning of "jet fuel" to step back and realize that a fire is a fire and under the correct conditions, they can burn at pretty extreme temperatures despite what exactly is one part of the fuel for it.
exactly, I feel nobody can come to an unbiased conclusion at this point.. most people have only watched a few biased videos, thats what upsets me the most, I like to try to be the other side of the debate, whether I personally believe it or not.
okay, lets say youre correct...and the people standing and looking out of the entrance holes of the building were standing across from the fire burning so hot to compimise the stregnth of the steal..causing it to collapse..
...then, why did the building come straight down at terminal velocity? wouldnt it have cocked over and fell one way?
Exactly. The steel in the WTC's was certified to burn at 2000 degrees for over 6 hours. It was high-grade steel, of much stronger integrity than that of the Madrid hotel, and the Madrid hotel didn't even collapse. Yet you seem to think stronger, certified steel was weakened and collapsed by a fire than burned FAR shorter, less hotter (look at the pics for yourself, if you believe otherwise you are in denial) than the fire in Madrid that DID NOT COLLAPSE THE WEAKER STEEL.
I want to address the jet fuel issue. I am a chemist before you say "hey, we're not scientists, we have no idea."
In a confined space, with only one entry for air (the hole that the plane left), you're not going to get a steady feed of oxygen that would promote super hot burning, plain and simple. Burning in air itself will not provide enough oxygen to get super burning out of jet fuel. Air is composed of ~20% oxygen, no more, no less.
So before you "quit playing physics teacher," think about the argument you're making. And to add a bit, I've take a few material science courses as well, and a lot of alloys used in building will get stroger to a point with heat. I'm not familiar with the exact alloy used in the construction of the towers, but being 100+ story buildings, I would make the blind assumption that it was carefully choosen to handle incidences such as fire.
P.S. Concrete doesn't burn.
I understand this, but its still a possibility.
You would be too if you had to deal with these people and their vodoo-"science"
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Anyway, im outie, later poopfaces!
Crown_amps
Banned
Crown_amps
British Columbia
Imtjnotu
