The Line Array Thread
re: The Pic
I think that is a Pyle super tweeter.
On diyaudio.com, one guy like the Pyle and has a pencil eraser mod to make
is sound better. :unsure:
You'd have to search their archives, maybe a NSB + Pyle search.
I'm too lazy to do it //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
If you really want to destroy people, make a matrix array with a high end horn,
a good compression driver and big lense.
ie,
http://home.pacbell.net/lordpk/misc/Feandil.GIF
Even 1 column is cool. I just drew a few columns for reference.
I consider the tweeter the heart of a good loudspeaker, others disagree. At any rate,
some of those cheap super tweeters just sound nasty and can make your NSB
look bad. If you have a high output, high quality sounding tweeter it will really
make the system as a whole perform better. You can later cone treat the paper
cones on the NSB's to refine the sound and you can also tweak crossover settings
to optimize. It's easier to fix the NSB issues than to fix the single cheap tweeter.
http://www.rawacoustics.com/
Oh hells yes.
re: the pic
If fountek ribbon, $118.
24 x $118 = $2832
I don't know what midwoofers they are, but even if you assume they are cheap
at $30 each, = > $1000
At least $4k for parts.
/hehe
If you can sacrifice maybe 5 - 15% in SQ, then make a Dayton/PT2 array
like this one and run it active;
http://www.caraudioforum.com/vbb3/showthread.php?t=224281
Driver cost is;
16 PT2 tweeters = $400
16 Dayton 6" midwoofers = $432
Driver cost = $832 {cheaper than $4k + }
Get two proamps and digital crossover and it's ownage.
Plan B, save $400 and use cone treated NSB's ported instead of Dayton, works very nice because
the tweeters are really the secret weapon.
Basically, PT2 SQ is marginally less than those $118 ribbons, 5-15% less on average, but PT2 is a more robust tweeter and can
take major torture without frying.
After months of my line array punishment, I finally blew PT2 fuses after cranking Slayer into major clipping.
I heard stories when people blew the precious 'fountek' ribbon on system turn on transients, you know
those little pops..
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Another version of the Straight 8...using Dayton drivers, IIRC.
Next to some killer Fostex full ranges. And a pair of 300b SET's chilling in the background.
brandontw
just some guy
brandontw
Reno, NV
PV Audio
