The front baffle is your problem.
The rest of the box you can do whatever you want.
I have a bad memory and too lazy to read this thread again,
but are you doing 16 NSB per tower right? When you cut a bunch of holes for an
array, the wood is not strong. Particle board would be ultra weak, plywood
would be strongest, and MDF in the middle. You don't need esoteric plywood
for the project really, just make sure that the plywood sheet is flat. Plywood
and hardwoods can be warped so examine the wood closely. Cherry pick
the best sheets. Particle board and MDF is less problematic.
The second issue, if you use 3/4" thick front baffle, the hole you cut will choke
off the NSB air space. Realistically it will work but it's not ideal, SQ may suffer.
I had to chamfer the rear baffle NSB holes which makes the front baffle even
weaker. If you use a 3/8" - 1/2" thick wood with just a hole, this is better if you
don't want to chamfer, but a front baffle that thin would have to be plywood for
best strength. The rest of the box can be whatever you wood you want.
What center to center spacing do you seek? If you spread out the NSB's more you
can make the front baffle alittle stronger.
