There is an NSB/PT2 array in my house with;
10 PT2 per tower.
16 NSB per tower.
4 chambers per tower, 1.5 cu. ft. per chamber
100hz tuning, ~ 6dB peak
Four 6" ports per tower, one per chamber
2 ohm wiring
2.4kw pro amp
+ room gain
Gives me a clean 126dB peak c-weighting SPL when listening to bass guitar on my Jazz DVD, midrange SPL peaked around 122dB, at the listening position.
This is using the Radio Shack cheapy meter. I like loud and clean music and
even 115dB c-weighting is pretty crazy for most people. Usually when people
come over they think it's loud at volume number --> 1 [lol]
There is no subwoofer installed right now to complement the array because the array is not for me, I'm holding it for friend and still tweaking around on it.
The part that amazes me more is -> the power handling, I high pass at 65hz,
LR 8th order, drive the amp to clipping, that's 1200w/ch and the NSB don't smoke. I was able to smoke them on my five NSB test box with the Adcom 200w/ch amp, but not the big array using the 2.4kw pro amp.
There is power in large numbers, like an army of ants //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Whatever you do, that NSB frame lip is 'teh svck' and you have to make sure
you get the right size hole to ensure a good seal. I had to modify my rabetting tool to get a precision cut so the NSB fits perfect. Then use PE rope caulk to make
a perfect air tight seal. Any air leaks ruins performance.
Also, the front baffle if 3/4" thick or greater chokes the NSB backwave {backwave compression}, it's better to chamfer the holes on the backside to allow the driver to 'breath'. This weakens the front baffle though so pick a driver spacing that you can work with, maybe a 4 3/8" to 4 1/2" c-t-c spacing. I reinforced the routed rear baffle with little blocks so a karate chop won't break the baffle
Even thought some people disagree with NSB SQ, you can make them do amazing things if you pay attention to design details and optimize everything.
The real heart of the system is the planar tweeters, they steal the show, the
NSB's are backing vocals - //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
