Temporary Install
GCAdidas13
heh.
Just wanted to let you know that I'm not dead and I am still on my way to the "finished" system.
GO BUCKS
It's just temp for now. But plans are to cut the kick panels that are there so that only the back mold part and the part holding the horn is there, and re-fiberglass a front to hold the speakers, and make the whole thing a lot more sturdy. THEN i will have my legroom //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how many watts is the dip recieving? what's the VC config on it? how many mils of xmax will it give your buttcheeks?
If by dip you mean speakers, it's 125wRMS, 8ohms, and something like 6mm iirc.
Better hope cabin gain helps you out a TON.
Those speakers in .3cuft = F3 of around 130hz.
F3?
I still have req's RTA so i'll be using that to do some tests
F3 = point at which the response has fallen by -3db....essentially the point where the speaker's low end response starts to roll off.
So, in free-space the response of that speaker in that volume would be -3db down at 130hz, and would have a relatively steep roll off below that....
Cabin gain is going to be your best friend at this point....
GCAdidas13
heh.
GCAdidas13
Grove City, OH
GCAdidas13
