ice, try and get all those little hairs covered in resin, you dont like sanding, so get em flat.
jigs are fine. jigs are fun. go for it. dont worry about the foil or tape. it will be on the back, noone will see that part. resin right over it. but dont put any glass on the backside of the lip you made. and the props can mount anywhere you need them to. as long as they dont get in the way of the speaker motor or the stretched material.
good so far man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
honestly, glass was prolly not needed on the rear part. that fleece was pretty thick, but it cant hurt //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
WHA WHA WHHHATT?? NO PICS OF YOU+SHOWER //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
on the dash...you want your soundstage to be ear level
LMAO!! //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gifi think one of my problems was that i didn't have the material stretched tight enough behind the wood mount, so i used some claps to hold the fleece tight. didn't have enough claps so i improvised and used jumper cables //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
then i measured to make sure the piece was in the center and hot glued it down.
I know...pure genious...might as well put those clamps to work...those are strong bastards too...prolly could crush your finger!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifhey man it worked //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif wish i would've done that on my last pods. i know for sure i'll do that on my other pod
ya ice, i would really recommend NOT putting tweets in your lower doors. tweets sound real good off axis up in the A pillar. if you put them in the doors with the mid, chances are that your leg will be blocking\absorbing a lot of the higher frequencies and it will be muddy as a result.
i would put the crossovers under the dash, and put the tweet in the A pillar.
what components do you have by the way?
