req
am a mod.
sweet then!
its the same idea. you might want to try some kind of larger 8mm or 10mm selftapping screw tho, small ones like that tend to wiggle out.
MAKE SURE you put the screws in a place where you can get them out thru the speaker hole tho LOL.
ALSO! when making the speaker ring, make a flushmount one, and TRY to get the face of the ring flush with the door panel. aim it up and over JUST A BIT, but try and keep it as flush as possible but make sure its further out than the door panel by like 1\2" or it wont stretch right., and make the "lip" from that red fleece that goes over the door panel like 1\2"
it will make it look nice and smooth.
*nother tip
put some plastic between under the door pod and the door jamb and into the floor of the car. that way you wont spill tons of resin all over the ground and the car like icetee did eehhe //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
*nother tip
