req
am a mod.
if you dont mind the threadjack teeman.
he has WAY more depth than i did. so his will be eaiser and wont have to build out as much. it all dependson the car and the size hole you cut //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you can see the REALLY THIN and SUPER STRETCHY material i used, thats a MUST. if its too thick, then the lip on the back where it overlaps the hole you cut out will not be flush with the door (because you will soak it in resin)
i think its pretty self explanatory. just make sure the wood piece you mount inside the door is like 1~2 inches smaller than the actual hole you make in the door panel, otherwise you wont be able to slide the whole pod in when you are done //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i also suggest rounding the edges of the baffle you make with a router. it would look much much better- too late for me however //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
*icetee*
also pull all the tape and foil off and try to resin the back side too. id put glass there before the inside. eaiser to apply!!
BIG TIP!!!
SHOOT YOUR ALUMINUM FOIL, and tape with spray adhesive and wait till it tacks- then aply it. then do the same with the other side of the aluminum foil and the backside of the fleece - its WAY eaiser than hot glue this way. and you can pull up the fleece and stretch it more without ripping the foil and having small lumps from the hot glue //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
*icetee*
BIG TIP!!!
