damping factor.......does it change with frequency? Damping factor drops as impedance drops, so can a 1ohm stable amp be designed ground up to have an good damping factor with typical amps running 4ohm loads?
I know impedance changes with frequency, but when it becomes too high at certain notes, does the amp lose output at that frequency? Does it play the note softer?
Does impedance rise do the same thing?
more to come later as questions are answered......
