Tech question about 2 chan. amp running 1 ch. at 2 ohms
crazydude133
Ok,,, I am lookin around all sorts of sites that sell amps and for the specs i never see ex. 200watts x 1 rms (2ohms) for any amp that is 2 or more channels. But... it often says ex. 100wattsx1rms(4ohms). so can a 2 channel amp be bridged to one channel and run at 2 ohms?
Another side quetion for yah,,,,, if i get one of those 50x4 pioneer decks can i bridge any of those channels?
Thanks
You can run an amp 2 ohms mono. Chances are though, that it will over heat within a couple minutes.
What happens when you bridge an amp is that each channel sees 1/2 the load. So if you bridge and run at 4 ohms, the two bridged channels see 2 ohms each. If you bridge to 2 ohms each channel is only seeing one ohm. Not many amps are built for that kind of current.
And I do believe there are a few recievers that have bridgeable channels, but they're only going to give you probably 30-40 watts rms so it's really not much of a gain, especially if you're wanting to power a sub.
Yes,, i understand now thank you.
About the deck,,, i am gonna have to find out what decks can do that cause i am only plannin on runnin 2 speaks of the deck,, and i want more power than what only one ch. can put out
crazy dude133---- check out kickers
kx 550.3 it a three channel amp
rated at
75x2 into 2ohm stereo
plus
400x1 into 2ohm bridge/mono (class d)
give it a look at (kicker.com)//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
That kicker amp seems pretty sweet,,,,,, I am just wondering cause i think that the 75 x 2 would be used for mids and highs but i havent seen any ex. 2way speakers... that are 2 ohm. So how would you wire them into 2 ohm so that you are still in stereo?
I hope u get what i am sayin
thanks
I wouldn't try to bridge an HU amp. I doubt that most HU amps are 2 ohm stable. Besides that they are not built to dissipate the heat that the internal amp would create resulting in poor performance anyhow.
crazydude 133--- you can wire a 6'' mid bass
a 4'' midrange and tweeter on one channel
for a 2ohm load in stereo
or a pair of coaxles on one channel
on the kx 550
then use the 3rd channel (class d
for your subs
you''ll be better off using a amp(more power)
then you would be trying to bridge
your headunit:cool:
crazydude133
crazydude133
Canada,bc
billetz23
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
