Tech question about 2 chan. amp running 1 ch. at 2 ohms
crazydude133
Ok,,, I am lookin around all sorts of sites that sell amps and for the specs i never see ex. 200watts x 1 rms (2ohms) for any amp that is 2 or more channels. But... it often says ex. 100wattsx1rms(4ohms). so can a 2 channel amp be bridged to one channel and run at 2 ohms?
Another side quetion for yah,,,,, if i get one of those 50x4 pioneer decks can i bridge any of those channels?
Thanks
You can run an amp 2 ohms mono. Chances are though, that it will over heat within a couple minutes.
What happens when you bridge an amp is that each channel sees 1/2 the load. So if you bridge and run at 4 ohms, the two bridged channels see 2 ohms each. If you bridge to 2 ohms each channel is only seeing one ohm. Not many amps are built for that kind of current.
And I do believe there are a few recievers that have bridgeable channels, but they're only going to give you probably 30-40 watts rms so it's really not much of a gain, especially if you're wanting to power a sub.
Yes,, i understand now thank you.
About the deck,,, i am gonna have to find out what decks can do that cause i am only plannin on runnin 2 speaks of the deck,, and i want more power than what only one ch. can put out
crazy dude133---- check out kickers
kx 550.3 it a three channel amp
rated at
75x2 into 2ohm stereo
plus
400x1 into 2ohm bridge/mono (class d)
give it a look at (kicker.com)//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
That kicker amp seems pretty sweet,,,,,, I am just wondering cause i think that the 75 x 2 would be used for mids and highs but i havent seen any ex. 2way speakers... that are 2 ohm. So how would you wire them into 2 ohm so that you are still in stereo?
I hope u get what i am sayin
thanks
I wouldn't try to bridge an HU amp. I doubt that most HU amps are 2 ohm stable. Besides that they are not built to dissipate the heat that the internal amp would create resulting in poor performance anyhow.
crazydude 133--- you can wire a 6'' mid bass
a 4'' midrange and tweeter on one channel
for a 2ohm load in stereo
or a pair of coaxles on one channel
on the kx 550
then use the 3rd channel (class d
for your subs
you''ll be better off using a amp(more power)
then you would be trying to bridge
your headunit:cool:
Another piece of cool equipment I've got is the Apt Holman preamp. That's running the other GFA 555. Only downside there is I've got to use a...
18
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
563
crazydude133
crazydude133
Canada,bc
billetz23
    May 20, 2024
    May 20, 2024
