taking the back seat out for subs....
i did not cut any thing out
i'm assuming that picture represents using the trunk for the box space and the sub facing into the cabin
well if you look in the pic there is a big *** steel support running right down the middle of my trunk opening. Not to mention the openings themselves are only 13" and i will have 15"s. The baskets will BARELY if at all fit through one of the openings
ya and i did not see the pic you put up in tell 5 sec ago. so that is my bad here is a pic of what it will be
picturebv6.th.jpg'%20alt='picturebv6.th.jpg'>
nice paint job, bagged on 20" Foose nitrous rims
http://www.mhtwheels.com/wheel.cfm?brand=4&cat=112
thatll work too lol
Honestly you should have a problem if you cut out that center support. Its a frame car, the body just sits on there, if it was mine I would wack it out. Then if you are worried about it later if you sell it or give it to your son just swinf by a body shop and have them weld some box thubing there, it will be stronger than factory.
thatll work too lol
well if you look at the pic with the amps showing...that space up there is only 13.5 tall from floor to deck so i would have to run 12"s in there and i want 15"s for sure.
yea you are right, just sayin on the support. Do you plan on laying with the 20's on there? If so you are gonna have to modify some stuff, there is not alot of room in the fenderwells front or back. I have had 3 of those cars, to lay the back you have to notch the frame, you can take the springs completely out of the back and it wont lay
not gonna lay it.
bonesninja
bonesninja
Lima, Ohio
jdawg
