tailgating system
mattstrauss
hey, i want to put a system in the bed of my truck for tailgating. how can i do this so i can switch between my system in the car and the system in the bed? is there some kind of switch or anything? i am clueless. any help will be greatly apriciated.
ps: the system will consist of the following
2 subs
2 amps
4 6.5 coaxials
Just put a cheap $60 headunit back there with the rest of the gear, and you're set. It'll be easier than having to keep running to the cab of the truck to change CDs, volume, etc.
If you did want to have two "seperate" systems, you could always use a relay and switch. Just make sure the relay you use is the one that has 5 prongs on it. You can wire it so when the switch is one position, one set of remote wires turn on, and when it's in another the other set turns on.
im still a little loss guys. i want two systems because opening the doors isnt loud enough. I already have focal comps, and JL w3's in the cab. is there a way to power a headunit in the bed of a truck?? how would I do this? can i just power one to play cds only and not worry about dealing with wiring the radio?
When I open my doors and play music its loud as hell, I think you need new components and more power to feed them. I have CDT Audio HD62's on 150rms and if the doors are open it sounds like I've got some DJ speakers going on.
its also more of the WOW factor. i think itd be cool as well to show off a little //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you are going to be engine off i would get some high capacity deep cycle batteries. in that case i WOULD do an isolator. something like a kinetik 2400 120+ aH(they have 3 batteries over 80 aH) or something close to that.
As somebody suggested, definitely get a few deep cycle batteries if you plan on playing the system with the engine off.
Anyway, there are quite a few ways to do what you want.
The simplest way would be to just wire up both systems to the head unit in the cab, assuming it has a remote for ease of use, and then wire up a way to switch between the two speaker sets.
You could also put an entire HU and everything in the back, just extend power wires to the bed and use a switch on a constant 12v for the remote.
mattstrauss
mattstrauss
orange, ca
JustStoppingBy
NorthFramingham
    Jun 30, 2026
