Tahoe/Suburban Power wire routing
WaTTsLOk187
Tu Papi
I have a 99 Yukon Denali that I want to put 0 gauge wire in. It is the same except for the front fenders/grill as the 99-00 Escalade and 99 and under Tahoe/Suburbans. Any of you that have done an install in one of these SUVs find a spot to run the power through the firewall on the passenger side? Or would it have to run all the way to drivers side. It would look alot cleaner if ran on the passenger side. If you have pics that would be great also.
Thanks in advance
Jimmy
Run it on the passenger side. If its the same as my 98, there is a nice spot right up under the heater that has factory wires coming through. I ran 2 runs of 4 gauge right beside that. You can see the spot easily from the engine compartment, and its a straight shot to the battery.
Thanks I'll look more closely and see if I can spot it.
WaTTsLOk187
Tu Papi
WaTTsLOk187
Los Angeles Ca
ngsm13
