HELP!! CD Installation Pontiac Sunfire
blgaudio
Im trying to help a buddy put a aftermarket radio in a 1997 Pontiac Sunfire. It has a security system protecting the radio evidently. He has tried to hook up two aftermarket hu's and they will both work until the volume is turned up then the only thing to play is a beep and then the cd player wont work. It will do the same thing with a factory hu, if it is not the one that come in the car it will display LOCK on the screen. Any help would be greatly appretiated.
first time hearing that. did u use harnesses or are you hard wiring everything. if you hard wire the whole thing i doubt it would do that since all u would connect would be +12, acc, ground, and the speaker wires.
blgaudio
blgaudio
Tennessee
Calikid
michigan born
    May 14, 2026
michigan born
    May 14, 2026
