WeeeeeeIm following you, and i agree that people tend to push their subs too hard. RMS ratings are too often seen as a minimum power requirement, and has helped to popularize the notion that 'underpowering' your subs is a bad thing.
Yes, you could eliminate the spiders, if your moving mass was zero. We are saying the same thing...
The typos make it hard to understand exactly what you just said, but if you have a legit way to eliminate spiders, I bow down to your intellect. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifI'm not trying to sound like a know it all but I have a idea on how to completely elimate the spider but it's going to rake some aerious pecersion and special circuitry in the Amos to work..
This reply seems to indicate you are only talking about coil rock, lateral motion. But the spiders also help with linear damping.. transitioning from the cone moving one direction, to moving the other. Unless Im not following you exactly.It's so easy in concept you would say **** why didn't I think about that..Key is to keep the mass perfectly linear in stroke..
