system overview
AllDayMJ
VR4 power.
So..tonight i got a check for 330.00 from my buddies roomate who decided he'd buy my 2 DD 512's and alpine mrp-m650 w/ 3.8 cube box tuned to 38hz..
right now i have 223.xx also in my biolife account..and i have an appt. tmo at 1 to get that up to 243.xx, which i am hoping to purchase a PowerBass asa 1500.1d for 240.40 shipped http://www.millionbuy.com/powasa15001d.html
once that check clears..and AQ decides to stock some d2 coiled hdc15s..ill be putting 289 towards that and doing a similar 3.7 cube box outta 1"MDF with 2 6" ports tuned to 38.5hz...
I also need to save up about 70 for a box all inclusive, along with about 46 for 25ft of there 0ga...
I plan to re-use the 4ga in my car to finish up the big 3 a few times over, probably 2-3 runs of 4ga per area(bat ground) (alt + to bat)(and alt grnd) since i already have 2/3 of it done should be pretty solid..
otherwise the plan is purchase a Deka 9a34 batt for 120+shiphttp://www.remybattery.com/Products/Deka-Intimidator-Battery---9A34__9A34.aspx if its really needed..
so...what are your guys thought about the system and choice of brands/ deals i found..?
idk, but is 2-3 runs of 4g is better than 1 run of 1/0g?
well most distro blocks are 1 1/0 ga in, and usually 3-4 4ga out, so yea, it should be relative, as long as the lengths of the wires are similar and kept to a minimum..
AllDayMJ
VR4 power.
AllDayMJ
Salina, KS
AllDayMJ
