System Not Working!!! Help
skitheec
Ok so I installed an Alpine system in my car back in June and it has been running great.
It consists of:
Alpine Head Unit CDA - 9886
Alpine Amp PDX - 5
Alpine 10" Type R Sub, 2 6" Type R's, 2 6"x9" Type R's
Like I said it has been running great and is usually turned up around 18-20. For the past week when I turn it up above 14-16 it just cuts out. The power stays on and it does not pause. The only way for me to get it to play again is to reboot it.
What do you think is causing this?
Thanks
No the rest of the electrical has been fine no lights dimming or anything. I checked all the wires unplugged everything from the amp and reconnected it, with the same problem. Ill def check the ground tho I never looked at that. Why would it only shut of above a certain volume tho? Do you think one of the fuses could be shot or something along those lines?
It was a team effort. A guy I know that works at an audio shop helped me install it. he has been working on systems for 8 years. Should I move the ground to a new area?
Alright I'll Check that out. The system doesnt turn off. It will be playing fine no cracks everything good. Than once I get to about 15 it just stops playing. It doesnt pause because when I press play again nothing happens and skipping to another track does nothing. The only way for it to play again is if I turn it off than turn it back on. When I turn down the Sub, Bass and Treble it can play up to about 18 Than cuts again, and that with the Sub at 10 instead of 15 and bass and treble at 0. Max on the sub, bass and treble is 15, 7 and 7
thanks
Okay so I checked out the ground and thats not it. I sanded it off there was some rust on it and still didnt work. So i moved it and still nothing. Still the same problem.
skitheec
skitheec
NJ, NJ
Toone
