System installed but need settings help.
jrotten65
MA
Sorry if this is the wrong area to post this. So I have a kenwood headunit and a clarion xc1410 amp and polk db651 speakers. Ill post links to them below but basically I've only ever installed subs and amp before with no issues. This amp has a switch for 60hz,90hz or flat setting. Trying to find out what setting i should have that on with these speakers. This install is in a Harley Davidson street glide in the front batwing so i need more treble and loud music over bass. Also do i need to adjust settings on the headunit for these speakers and how should I wire them? they're 4 ohm speakers and the amp is a 4 ohm amp. The amp is 50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms) and the speakers are 60 watts rms they say. I'm also looking for suggestions on better speakers for this amp and headunit for louder audio or the best way to wire them. I can use 5.25" or 6.5" speakers. Sorry for the long post and if this is a headache I've just had no experience with fine tune settings and what not.
amp - Clarion XC1410 Compact 4-channel amplifier — 50 watts RMS x 4 at Crutchfield.com
speakers - Polk Audio db651 6.5" dB Series Marine Grade Car Speakers
headunit - Kenwood KDC-BT562U CD receiver at Crutchfield.com
If your only running two speakers why didn't you just get a two channel amp? Anyways you can put the switch to 90hz and adjust the gain and other settings accordingly make sure bass boost and all other "loud" features are off
Sent from my 5054N using Tapatalk
jrotten65
jrotten65
MA
dev199505
