Amp trouble hellllpppp!!!!
yroc434
Va
ok so i just ordered a pair of SA-12's and a CAB 1600.1 amp! all wires have been installed and done so correctly! Grounds good as well! i get NO power to my amp! Fuses are good throughout car and on power wire as well!! if i take my REM and connect it to my 12v constant i get power but no power any other way! PLEASE HELP!!!!
wires are not done and installed correctly or else it would turn on. Check for breaks on the line and check all connections bro. It happens to the best of us.
I just ordered new 0 gauge to be sure
I needed new wire anyways, i had a slit in the power wire and i just put Electrical tape over it! Also i was running 4 gauge and wanted to run 0 gauge
Not my first time by far! This is the first time ive ever encountered this problem! I never even changed the wires after i unhooked my last amp, just plugged everything back in on the new amp and nothing, plug my old amp back in and works fine!!!!
yroc434
yroc434
Va
Boomin_tahoe
