system install wonder....?
C1500martin
so today i was finishing up the install in my truck this is my equipment
HU: Clarion CZ702
Mids&Highs amp:RF Punch 500x
comp set: JBL MS62c
Sub amp: RF power 1001bd
sub: Dayton HO 12
1/0 ofc wire into KNU distro to 4 gauge cca for amps.
1/0 ofc big 3
stinger volt meter wired up to the sub amp.
My problem is that once i connected the neg battery terminal amps and volt meter turned on... but not the HU. once i turn the key into acc the HU turns on. but the whole time everyhting else is on.. they all are hooked up to the same remote wire. WHY DID EVERYTHING BUT HEAD UNIT POWER ON!?!?!?! i am bewildered by this. please chime in fellow community
What do you mean they are all hooked to the same remote?
Are you using the same remote as the actual headunit or the remote wire provided by the H/U
Sent from my Z970 using Tapatalk
well the thing is apparently when my old HU was installed the idiots who installed it CUT my stock harness so now all i have is 2 wires. a red for power, and a blue for remote turn on. both amps and volt meter and HU are all connected together to the remote turn on wire. the single wire splits into 4 different places.
C1500martin
C1500martin
Cali
Boominburban
