system improvements
any speakers will sound like crap at high volume..
high volume=DISTORTION.
distortion=not good, can cause hearing loss, etc.
turn it down.
and also amp them as well.
no hu puts out clean power as it is, let alone at higher volumes; it just causes severe distortion/clipping
as for the "big 3", check the wiring section for the stickied tutorial.
turn it down.
Most speakers do not sound like crap at high volume. High volume does not equal distortion. Driving components past their design limits does. Distortion does not equal hearing loss, high volume does.
About the only thing that you said that contains a shred of truth is that an amp for the front speakers would be the single biggest improvement that he could make to his system. Real power from a dedicated amp will allow his speakers to play louder without distortion as opposed to the 10% distortion that is typical for rated output on most all headunits.
i didn't say distortion WILL cause hearing damage, but it ADDS to the potential.
and usually at high volume you will get some amount of distortion, regardless (if HU running speakers; amp will put cleaner power)
poolplaya2626
poolplaya2626
Chicago
dkguitarist
