System cost and thoughts
Cages2Clouds
19
O'Fallon
Hello guys, what are your thoughts on this system and is it a fair price? Finally what do you think instalation will cost?
A SAE-1500 watt amp $409.99
2 SA 12's $419.99
Amp kit wire free
Pioneer AVH5800BHS $314
SA-6.5 CX - Sundown Audio 6.5" 50W RMS Coaxial Speakers
SAE-50.4 - Sundown Audio Monoblock 300W RMS Class AB Full Range Amplifier
SD-6.5 CS - Sundown Audio 6.5" 60W RMS Component Speakers System $519.99
Total $1663.97
A cab 1600.1 watt amp $200
2 SA 12's $419.99
Amp kit wire free
Polk db comp sets. $200 for 2 sets
something like ppi 900.4 4ch $150
This is what I'd do if it was my money.
decent price, you would save money doing the installation yourself. installing is fun!
Honestly I would love and have a blast doing so but I have no idea how to not do I know anyone who does and would just be so worried about screwing up the system or my car. I'm not completely ruling it out but chances are I'll go with a professional install.
No sundown helps cab. That cab 1600.1 is decent and $200cheaper then the sundown 1500..
Awesome, I found the polks on Amazon for a lil over $50 a set so if those aren't lacking in performance other id save a lot even with having to buy wiring. (The free working was due to the bulk buy at one place)
I'd go with this over an sae
* NEW * CAB-1600.1 Amplifier - Car Audio Bargain
This for a korean built 4 channel class A/B.
FSD Audio FZ 125.4 125-Watt 4-Channel Amplifier - SounDrive Audio Store
Polks are better. Sundown isnt a company thats known for great component speakers. Their Neo-pro mids are decent but everything else is bleh.
Subs are okay. Most of the cheaper recommendations already are reaching sundown prices nowadays.
Would you recommend the FSD Audio FZ 125.4 125-Watt 4-Channel Amplifier over the PPI 900.4 4 channel?
I like the comp sets. Each one you get
two 6.5"
Two tweeters
Two crossovers
So however you many you need
---------- Post added at 01:34 PM ---------- Previous post was at 01:33 PM ----------
That fsd 4ch is good shlt. Either will do nicely
I like the comp sets. Each one you get two 6.5"
Two tweeters
Two crossovers
How many crossovers do I need? I have zero equipment purchased as of now and as you probably guessed lil know how in car audio systems lol
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
184
606
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
Cages2Clouds
Cages2Clouds
O'Fallon
the727kid
    May 31, 2024
    May 24, 2024
