System Check
dr00mx
Alright guys i got
Sub Amp: Arc Audio ks 1000.1 2ohm 1000w
Sub: Morel Ultimo 12" 2ohm
Comp Amp:Arc Audio ks 300.4 bridged 350 x 2 at 4ohms
Comp: Morel Tempo 6
Now for this system to run what do i need as far as batteries and alt go?
Got '99 monte carlo 105A alt, stock battery.
if any one can help me out with what else i need so my car dont dim and kill the stock electrical.
thank you
Dan K
Just get an Optima from Autozone so you get a nice warranty, do the big 3, and go from there... If you still dim, get an alternator. I think you'll be fine though.
so red top under the hood then
Cold Crank Amps 800; Crank Amps 1000; Reserve Capacity 110; Ampere Hour 50
looky good?
and another questions with the anl fuses
my alt is 105A
is going
300a at the batt
150a and 100a at the splitter unsafe for the rest of the electrical?
any thoughts on what fuses i should use for my system mentioned above?
putting the yellow top under the hood will void the warranty. red top under the hood.
Can you post a link to where it shows that? Optima's site recommended the YT for under my hood replacement and did so for my other vehicles as well. I've never had a problem with warranty. It is always hassle free.
Yea im not sure about that warranty thing either, they also recommend a yellowtop for my car...and ive seen it advertised.
I would get a redtop tho unless your planning on deep cycling the battery, and do the big 3 as it does help with dimming.
Honestly, I can't imagine with that kind of equipment you'd be pulling a significant amount of current. I don't assume you're a basshead with that list...if you are, you bought the wrong stuff //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Upgrade the Big 3, and perhaps battery if you feel like it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
: ) that's what i said but there are people that think differently ;] hmm
this should push around 1200-1700w so im sure the stock with keep up
mayb sum dimmin and im sure yellow top would fix it right up
i just dont want my electrical fryin cuz i did something wrong
better ask then do huh
D*mn I didnt know putting a YT under the hood voids your warranty. I say get a redtop up front and maybe YT or something else in the back. I know you'll upgrade, its in your blood once you get started
dr00mx
dr00mx
Mokena, IL
Enellz
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
