Sundown Z15 v.2 Producton Unit - First One
sundownz
Pro Seller
Supporting Vendor
11,349
North Carolina
Built one yesterday to almost full production specifications -- only difference to production is a small change to the coil (those coils are not in stock yet -- they are the last part I need). So... that means once coils are in they are ready to roll for customers.
Specifications :
RE: 1.9 ohms (D1 in series)
FS: 42.2 Hz (5 minute break-in)
Qes: 0.480
Qms: 4.024
Qts: 0.429
Le: 0.980 mH
Vas: 49.725 L
BL: 16.238 NA
Mms: 251.09 g
Cms: 56.48 uM/N
Sens: 90.76 1w/1m
Sens: 97.00 2.83v/1m
FS will drop along with Qts as Cms increases with break-in.
Concentration of this design was low MMS and Inductance -- which worked out well as you can see. Spider compliance can be tailored to what is needed -- 3 spiders (standard) was used for the above spec measurements. I have put over 7000 watt bursts through a unit with only 2 spiders, though, so that is a great option for those not wanting to use huge amounts of power. Extra spiders can be added... I would never suggest more than five of these units, though.
* Light weight cone with narrow / tall surround (standard) -- optionally, the Nightshade cone can be used for ULTRA high power applications.. IMO, not needed for most daily setups (adds a good bit of MMS)
* Single lead spiders (standard) -- double lead are optional (anyone running amps under 1 ohm should get double leads, IMO)
A few big builds coming up for these as soon as they start shipping -- so keep your eyes peeled //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It could -- the top plate is 32mm tall.
Thats what I figured, the top plate did look huge, lol. In your opinion which motor would make the better underhung driver? SQ is priority 1, everything else be damned.
NS v.2 -- taller top plate will give you more linear throw with the under-hung topology. Both have shorting rings as well.
325
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
