Sundown Vs Dc Audio
Find something that has an efficiency bandwidth product of 55 ish or below. Just google up efficiency bandwidth product calculator and it should be the first result. You need to use speaker qes electical and Fs to determine if a sub works well in a sealed or not. Sone subs sound like pure garbage in a sealed.
Best one i've found is the Lethal Injection 12 Incriminator giving 52.6EBP and NVX VCW12 with 49EBP
DC does indeed give sealed enclosure recommended specs for their subs up to Level 4. I've yet to see someone do it though.
If I were looking at a 750 watt sub from DC, I'd lean towards the Level 2 over the Level 3...unless you plan on throwing more power at it later.
rfkjustin
rfkjustin
delano, ca
ciaonzo
