sundown SFB amplifiers
Are you just refusing to type "sfb 8000 amp dyno" and "sfb13500 amp dyno" into youtube? 13500 makes over 8000W into 2 ohm and sfb8000 makes over 6000 into 2 ohm. 2 ohm is well within the realm of what you may see wired to 1 ohm nominal.
Im sure on a load bank it does 6k. My point is load bank vs reality is very different. That why they salt amps cost more. Your actually get rated power out of them.
Do you have any data to support this claim?
No. SALT amps cost more because they're built in Korea and use about 3X or more the amount of components, board, and heat sink. They also cost more because Sundown can charge high for them as their flagship series. It is likely that you could have the exact same amps built in Korea for 50% of MSRP or less.
That's the point the 12k have a 2 to 1 power supplys and outputs are truly 2 to 1. Hence the fact they can run it .33 and .25 because the power supply can actually produce the 125 volts and 125 amps to make rated power.
Tooing for the amps is around 10 racks
For each line.thats JUST TOOLING no materials.
Meanwhile the transistors used in the sbf aren't 2 to one. And the rumor of full bridge not taking low low loads is a load of shit. They just have to be built for it. The sbf is the budget line I know but I'd stick to taramps bass at that price its a no brainer. Which is what I ran. .5 all day as long as you don't clip it to death and the 15k in 1k. Videos showing actual real power of 13500.
StreetLegal.
CarAudio.com Newbie
StreetLegal.
Canada
hispls
vegang
vegang
