Sundown sa-8 t-line power limit
hmm... so thats what that is. ive seen a lot of people with home systems using t line enclosures and wondered what they were called. **** those things are massive... do you sacrifice bandwidth for output with these?
No you don't. A t can play a full octave below box tuning.
The whole purpose of a t is to get loud on little power. My one hds210 was 25-30% louder than when I had both in a ported. On the ported box I was giving both subs 1200rms@1ohm. In the t I was giving the one 600rms@2ohm.
So will it be true that I could built a L port box and give it tons of power and would be as loud as a t-line?
All depends on what you mean. If you're saying an 8" in a ported with a lot of power compared to the same 8 in a tline on less power I would say the t will be louder. I got a big increase using one sub against the two in the ported.
See problem is space. If that wasn't an issue I would get a re sx 12 since I love the 18 I have. But they call for so much space to sound good. So the sa 8? So I will have to find a good amp. Might just get a sundown 600
So again what's the power limit. Do I just stick to the rated or over/under... How would I be able to tell or is it something I would just have to try out?
sharkman
poor bass head
sharkman
oakland ca
CSCStang
