Sundown Audio Nightshade 18'' -- AQ2200 >> Truck Build
The slant won't affect it as long as the port doesn't touch the baffle. Make sure you leave a port's width away from the bottom of the box though.
Think it will be noticably louder if I port up compared to the side?
Wrong.
Its half the diameter of the port(the radius) squared(so approximately 4x4) x 3.14 x the length of the port divided by 1728
That would be .66 cubes. I used 23'' as my port length. Which one of you is right? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Can we get some photos of the truck and space your working with? I have owned like 10 trucks single cab, extended, crew I might be able to give you and idea..
What I have done in trucks
Single cab
2 12's behind the seats
4 15's in camper coming through window
4 8's behind seat
crew
2 12's behind driver current subs
1 15" behind driver
6 12's blow though in window ( photos in my profile here. )
1 18" behind driver ext setup.
Displacement is how much room something takes up. I would think you would use the entire width and not just the radius, I could be wrong though.
no prob. I have 4.4^3 after displacements, not including bracing.
Think Im going to have to port through the top and leave some port hanging out to save room.
Single cab
4 8's behind seat
crew
1 15" behind driver
Yeah I can get some pics tomorrow or find some older ones i posted
Decided im porting out of the top of the box. 11'' in the box, and 11'' out. Box is 5.75^3 before displacements.
sub - .25
port - .32
double baffle - .41
4.75^3 after those displacements. Ill try to brace strong but with as less as I can.
you can use the 18 in 4.5 cubes, 3 10s are probably going to need a bigger box than that.
Not really, since a normal 10" sub needs 1-1.5ft^3 each, and you can get away with less since he'd be using a common chamber.
length of port x OD of port x 3.14 = XThen divide X by 1728
Nope.
Wrong.
Yes!
Nope again.
Yeah I think Spooney is right...my bad.
Indeed!
Bobby322
Bobby322
TX
HSWaypeType
