Sundown 3000d installed
lilmaniac2
Ask Me about SI Mag V4!
So Jake from Sundown made a trip up here to drop off some of his new amps so we could have some fun testing them. my clamp meter screwed up so I dont have any power readings handy, but i do know that drop in the saz 3000s were louder than anything else ive had in there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
on to the pics
So i guess ill release some more results, 110 vac into a.5 ohm load. Depending on impedence rise thats very possibly over 10kw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Interestings.
nG
Power output is very close between the two. Depends on what load you need as to which is better suited. As in... one 3000D for a 1 ohm load or two 1500Ds for a two ohm load (warrantied loads).
It's tough to drop in compare vs. a pair of 1500Ds as if each 1500D was seeing 1/2 ohm (1 ohm strapped) then the single 3000D would be seeing 1 ohm -- which, at solid voltage, would give the edge to the 1500D pair.
Chad is still dialing his setup in. I might take another trip out there and play around with it too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I want to go, Ride through Kannapolis and pick me up //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
It would nice to meet Chad and hear his setup
lilmaniac2
lilmaniac2
Somewhere, Else
ngsm13
