sum1 pls help me
timm
10
CA
i have this m3mojo 15 inch sub and a PG xenon 1200 but my problem is i have no box
pls sum1 here help me design a box i dont know much on building sub boxes
this is my free trunk space
31 width 17 tall 15 deep pls help me i want a 35hz port tuning
thanks
i already did no luckthey keep on giving me large deep dimensions
Not to be a d!ck or anything. But it's gonna take a pretty large box for three 15's. And your dimensions only allow 4cuft. I'm not familiar with your particular subs, but I don't think that's gonna be enough room for anything but a sealed box if that. Once you get the volume and tuning you need. You can play around with the different dimensions until you have something that works for you. You just need to make sure the end volume is what it's supposed to be. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would call Kenwood Tech support. Im sure they will try to help you
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
111
432
timm
timm
CA
timm
    May 31, 2024
    May 24, 2024
