Suggestions: dim
subzero
Hey guys,
Well, as you see in my sig, I upgraded my equpiment. So I ran 0/gauge and beefed up the battery ground with two 4/gauges. and alternator charge cable with two 4/gauges.
I been looking for a high output alternator but they are to exspensive. I got prices from $479 - $800.
Does anyone have any suggestions? I want to fix this issue before the OCT 17th show.
I called a alternator shop and the guy told me I need something like 100amps per 1,000 watts, so that means I need 300amp altenator.
He also said that I should have 1 battery for every 1,000 watts...
ok, well, I only have maybe $250 max to spend. If you have ideas let me know.
you are clueless....
not really, he asked for suggestions and i suggested that if his headlights are his main problem to upgrade to HIDs because they dont dim like stock ones do, //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
O.P. if you have dimming issues, then you really need the HO alt to keep the voltage up. what batts are you running right meow?
Well, I have standard autozone undwer the hood and a exide deepcycle in the trunk. Not just any dimming issues. Chit fricken blinks at you at high volumes. I have it geared for competition. I guess I will try to come up with the $ for the alternator. before the 17th...
wow I cant believe youre dimming that bad. my buddy had a dimming issue in a honda civic w a 70 amp alt(right around there)- we did the big 3 with 1/0 and added a blue top he's sitting pretty right now. He is running approx 15-1700 watt amp we had a/c and all lights on and it dropped .6 volts
Yup. 2000RMS @2ohms is what it is. I figure with the drain on the batts and shitty alternator I am seeing half that. I deffinately need an alternator with alota POWER.
subzero
subzero
Chandler, AZ
subzero
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
