dvc sub trouble
I wired each to 1 ohm and tried them 1 at a time on my Crunch p1500.1 which is 1 ohm stable and they each worked. Then wired them to 4 ohms each and put them both on the Crunch and only 1 worked. I changed the wiring back to 1 ohm on the one that wasn't working and it started working by itself again. So I know its not the amp or the wiring.
if the subs are working then it has to be the wiring. if you didnt wire them up to either the 2 or 8 ohm configuration on the link i provided then its your wiring. i can pretty much guarantee your amp isnt stable at .5 ohm
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
SRim23
BP1Fanatic
BP1Fanatic
