Some speakers are more efficient, but not 1% is converted into acoustic, it ranges generally 3-7% for most subs. If you want, I can prove this with a hell of a long equation that I do not want to explain. Hey. It's summer. Basically you can calculate how much energy is in a specific area from the output of the sub, compared to the origin. This can work with any sort of transducer, measured in dB. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYes it will be. Not 1000 watts of mechanical/acoustical power, over 97% of the power sent to a subwoofer is converted to heat, but it will still be 1000 watts of total power output.
Wrong, read this article it doesn't exactly apply to subs, but it does show heat is power.Heat does not equal power. Heat is loss.
Thermal power is heat but in a different application.
The heat does not do any work, thus its not power. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifWrong, read this article it doesn't exactly apply to subs, but it does show heat is power.
http://www.eejitsguides.com/environment/elec-voltage.html
Bingo. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifTransducer.
Actually incorrect, read the first page of this document where they go through the derivation of true efficiency of a sub. The vast majority of subs are under 1% of electrical power converted to sound.Some speakers are more efficient, but not 1% is converted into acoustic, it ranges generally 3-7% for most subs. If you want, I can prove this with a hell of a long equation that I do not want to explain. Hey. It's summer. Basically you can calculate how much energy is in a specific area from the output of the sub, compared to the origin. This can work with any sort of transducer, measured in dB. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sure tons, given the correct alignment...Can someone find me a subwoofer that is 7% efficient?
I doubt any of us would want it. You know, Hoffman's Iron Law and what not.
