subwoofer mounting question
mattldm
Trying to get noticed
When mounting a subwoofer in a sealed box:
Do you screw the subwoofer down on top of the box carpet, or do you cut the carpet out around the the diameter of the sub and mount the subwoofer directly to the wood....
Or does it really matter?
Carpet may actually be better depending what the back of the mounting surface of the woofer is... If it is bare basket, then carpet is better... If it has a rubber piece on the mounting part of the basket, then you may actually want to cut the carpet, although I wouldn't think it would be necessary.
as long as the sub has the rubber gasket around it it shouldnt matter wut u mount it on as long as its flat
just screw it down decently tight and ur straight
The sub in question is an Arc Audio ARC12d2. It does not have a rubber ring around the frame. It did come with some thin gasket material but I wouldnt think I would need to use that if I just mount it on top of the carpet.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Ha ha!!! I feel really dorky for getting that.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Thats OK I dont get it at all?
mount it with daemon tools or alcohol 120%
HAHAHA I think that thread was down about 5 clicks lol, but sure would make for one easy install.
Mount the sub over the carpet, if you screw it down square and tight all around the carpet should act as a sealer of some sort at the very least.
mattldm
mattldm
So Cal
jdc753
