subwoofer help or is it the box
dumbguygeorge
dfaf
i got 2 12 re hcs they have been very good to me but one is out of phase with the other. it is wired up correct and everything. rca are fine and so on ground is fine. could it be because i got a single port on the box and that the one that is closer to the port is movin out further. i dont no wat to do and how to fix it
ill try that could it be because my amp dont have a good ground or something like that? i personally think its the port on my box not enough port area or something
nothing worse then when your subs just sound
"wrong"... i went through hell trying to figure out
what "wrong" actually was...
i thought phase too for the longest time... have you
just tried running each sub separately to see if
maybe you can identify which sub is the culprit???
do you have a single box your could try the subs in? sealed
or ported... your just trying to find out what sounds wrong
at this point...
do you use a LOC?
no i dont got a single box, could it be the amp or something? the box is about 5.8 cubes after displacement and is tuned to 31 hz, and only has 1 slot port and it is 3" wide 14.5" high and like 11 deep. its a crx type box, subs fire up because i got a hatchback.
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
941
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
dumbguygeorge
dumbguygeorge
dfaf
dumbguygeorge
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
