IXL-10 v2 SL [iXL-10 v2 SL] - $149.00 : Mach 5 Audio
theyn make one designed for sealed and one for ported
its a monster prob the way id go if i was you. amazing subwoofer. 149 plus shipping
email him
New Page 1
his site is down
Mach 5 Audio IXL-10 - DIYMA.com
Mach 5 ixl 12 specs!!
here they are for however wanted to know...
IXL-12 Dual 1 Ohm SL (high Qt)
Fs *= 29.62 Hz
Re *= 1.80 ohms[dc]
Qt *= 0.69
Qes = 0.75
Qms = 8.01
Mms = 246.43 grams
Rms = 5.727948 kg/s
Cms = 0.000117 m/N
Vas = 27.91 liters
Sd= 411.87 cm^2
Bl *= 10.469828 Tm
Lp(2.83V/1m) = 88.25 dB
IXL-12 Dual 1 Ohm BR (low Qt)
Fs *= 30.23 Hz
Re *= 1.80 ohms[dc]
Qt *= 0.42
Qes = 0.45
Qms = 6.24
Mms = 201.64 grams
Rms = 6.141663 kg/s
Cms = 0.000137 m/N
Vas = 32.75 liters
Sd= 411.87 cm^2
Bl *= 12.332832 Tm
Lp(2.83V/1m) = 91.41 dB
IXL-12 Dual 2 Ohm SL (high Qt)
Fs *= 26.54 Hz
Re *= 3.70 ohms[dc]
Qt *= 0.68
Qes = 0.74
Qms = 8.58
Mms = 193.35 grams
Rms = 3.759525 kg/s
Cms = 0.000186 m/N
Vas = 44.32 liters
Sd= 411.87 cm^2
Bl *= 12.686647 Tm
Lp(2.83V/1m) = 85.77 dB
Fs *= 26.54 Hz
Re *= 3.70 ohms[dc]
Qt *= 0.31
Qes = 0.32
Qms = 6.24
Mms = 248.96 grams
Rms = 6.650503 kg/s
Cms = 0.000144 m/N
Vas = 34.42 liters
Sd= 411.87 cm^2
Bl *= 21.844589 Tm
Lp(2.83V/1m) = 88.29 dB
Run the SL units in 2 cubic feet with damping in the box. *The BR can
be used in 1.5-1.8 cubes with your choice of box tuning. *I suggest
anything from 32Hz to 35Hz.
heres the 12's specs, they like small sealed boxes
